Apple iPad & iPhone can’t connect to hub manager (6) using IP address. All I get is a blank page. Tried resets of devices. Still actually connected to internet so not a major problem at the moment but want it working in case of problems in the future. I have been able to see it up to today. Any suggestions appreciated.
Solved! Go to Solution.
Try clearing cache etc. under Settings> Safari>Clear history and website data. If no joy then I’m lost!
No joy, but appreciate you trying!
Do you use an adblocker on the iDevices? If so, try switching it off temporarily to see if that let's you log on to the hub/
Bingo! I was using f-Secure AdBlocker and disabling the content blocker on the hub manager page sorted it. Thanks for taking the time to post, it helps people with my level of tech knowledge a lot!
Great - glad you got it sorted.
