sirjamesp
Message 1 of 128
Can't send SMS
Hi,
My mobile (Moto G) is connected to the BT network - I can make calls and connect to mobile Internet, but cannot send text messages for some reason.
This problem started some time today - I've had no problems before now.
Any ideas? Are there network problems today?
Thanks,
James.
Tags (2)
127 REPLIES 127
sirjamesp
Message 2 of 128
Re: Can't send SMS
I should add... I can receive texts - I just can't send them!
Johniec
Message 3 of 128
Re: Can't send SMS
I have the same problem - I can receive SMS texts but unable to send
Lagerlager
Message 4 of 128
Re: Can't send SMS
Same here stressing me
Out , tried resetting but no help can not send normal texts can get them and make calls and use 4g but not send normal text
callumh26
Message 5 of 128
Re: Can't send SMS
same thing is happening to me aswell, does anyone know what the problem is? is there problems with the network?
Johniec
Message 6 of 128
Re: Can't send SMS
Just called and there is a national fault - they are working on it but no estimated time known as yet
Damien1
Message 7 of 128
Re: Can't send SMS
Same here would be nice if they let us know somehow
Damien1
Message 8 of 128
Re: Can't send SMS
The service stays page says nothing wrong with mobile network useless why have the page if you don't update it
MattandLottie
Message 9 of 128
Re: Can't send SMS
Can receive but not sent too.
Maybe a service message from BT would be good?
Oh of course its the weekend so no one in a position to make a decision is at work, just the low paid workers.....no change there then!
JMB
Expert
Message 10 of 128
Re: Can't send SMS
Just been going through the diagnostics which did not help at all!
Unfortunately with telecome networks, it is very much a case that if the computer says there are no faults then there are no faults as far as the people in network control are concerned.  Same on all networks!
MB
