Message 1 of 13
Can't send emails
Hello,
Can you help me I have Microsoft Ourlook 2010.
I have a Bt internet account and sub accounts which all work fine.
However I have two other email addresses with tiscali, one xxxxx.lineone.net and the other xxxx.tiscali.co.uk which recieve emails fine but they wont send.
Yesterday I verified both email addresses with Yahoo but I still cannot send.
Could you point me in the right direction please ?
Thanks.
12 REPLIES 12
Recognised Expert
Message 2 of 13
Re: Can't send emails
Is it not normal that you can only send from your isp smtp server which wont accept others ?
If any post helps tick the star box on the left
Just cause Im paranoid dont mean they are not out to get me
Message 3 of 13
I dont know that's why I was asking.
Sorry
Bye
Recognised Expert
Message 4 of 13
OK then that is what I have always found for normal pop 3 / smtp servers
Distinguished Guru
Message 5 of 13
@headers2 wrote:
Hello,
Thanks.
Hi.
Can you give any error messages you are receiving ?
You might like to take a look at my shortcuts option 0e - in case there's something that you may not have done. Typically it needs to be a setting or 2 in the smtp section of the non BT account which needs checking/amending.
If you're still having problems, just pop a reply Smiley Happy
Recognised Expert
Message 6 of 13
I have a very old and well loved freeserve address (from dial up account ) which I would like to send from via Incredimail and have so far failed miserably to find a way
Have browsed Andy,s very useful tips a few times and still can not get it
freeserve wanadoo orange and god knows how many other name changes since I first had this address .
Message 7 of 13
I think I've tried the steps in Andy's usedul tips but to no avail.
The fault is 'the server was interrupted'. I can't tell you more because I can't copy it and it disappears after a few seconds.
I have to say I'm not much good with this and I can log onto web mail so all is not lost.
However I would have liked to have used Outlook for all my mail accounts.
Distinguished Guru
Message 8 of 13
Hi again.
Can you email me via my shortcuts option 0e, and I'll see if I can help further. I may ask for a couple of screen prints of various Outlook settings windows. Any info found will be relayed back in "here" to help others if it works.
I thiink I've always managed to get this working in the end. Smiley Happy It's typically one of those items that is complex, but a methodical process can solve it. Of course, the process is not easy though !
Message 9 of 13
Problem solved
Smiley Happy
Many thanks
Can now use all my email accountys to send.
Newbie
Message 10 of 13
Hello, I have just joined btinternet and am going through this cannot send emails process it seems like many of us. I have changed the smtp server to mail.btinternet.com and done the account additions and verified the emails. I have done two separate ones because we use sub-domain emails within an email account with an isp called nildram which is part of Talk Talk. I am now at the stage where I am getting this error. I have checked that I have smtp authentication on the relevant account (Outlook 2007) so I am a little perplexed. Here is the error message.
Task 'Derek Evans Nildram - Sending' reported error (0x800CCC78) : 'Cannot send the message. Verify the e-mail address in your account properties.  The server responded: 530 authentication required - Your email could not be sent. To fix this you must make a simple change to your email (known as SMTP authentication). For advice visit www.btyahoo.com/smtp'
