Message 1 of 3
Can the BT Hub or BT Smart Hub 2 available to set up Bride
Previously I was with Talk Talk that the WIFI hub was able to use Bridge to a Belkin router. Because of that re-arranged my house so I could have two routers in different parts of the house.
Now I have moved to BT I have now realized I cant set up bridge mode and I can not trail another cable through the house to give internet to my Belkin router.
Does anyone know if I get another router that is compatible with T internet that will let me do bridge mode?
2 REPLIES 2
Message 2 of 3
Re: Can the BT Hub or BT Smart Hub 2 available to set up Bride
Get the extra smalls disc it sets up a mesh around the house .
Connect via the wifi ....
I have had no issue with these even working along side the Sky Q mesh with the mini box
Message 3 of 3
Not exactly sure what you are trying to achieve. You wouldn't have been able to have 2 routers operating in your house unless they were connected via an Ethernet lead. You don't need to put the hub in bridge mode to connect a second router in any case. You can connect the Belkin to the hub as a wireless access point or second router by using powerline adapters.
