Chrisayres
Message 1 of 3
Can you connect a Hub 6 to a Hub 5 to extend the WiFi down to my summerhouse via an Ethernet cable?
I have a Hub 6 in my home office and I need to get WiFi into my summerhouse at the end of the garden. My Hub 6 does not extend to the end of the garden although it is in sight of the summerhouse and it is only about 75 feet away.
Can I run an ethernet cable from my Hub 6 down the garden and into my old Hub 5 and if so, do I need to set anything special up on the connected hub 5.
Thanking you indavance. chris
2 REPLIES 2
smf22
Recognised Expert
Message 2 of 3
Re: Can you connect a Hub 6 to a Hub 5 to extend the WiFi down to my summerhouse via an Ethernet cab
Entirely possible and exactly what I do. Connect the ethernet cable between the LAN ports of the two hubs, then a couple of things to change on the Hub 5 are:
- the IP address to 192.168.1.253
- disable DHCP
Save the config and you're good to go.
Regards
Chrisayres
Message 3 of 3
Thank you for your prompt response, will give it a try and let you know when done. Thanks.
