Message 1 of 10
Cannnot Access Webmail - Redirection Issues
Hi,
I cannot access webmail - Chrome states :
"home.bt.com redirected you too many times."
Firefox states :
"Firefox has detected that the server is redirecting the request for this address in a way that will never complete"
Was working this morning.
Regards,
Shadders.
9 REPLIES 9
Message 2 of 10
Re: Cannnot Access Webmail - Redirection Issues
Same with me - what's the answer?
Message 3 of 10
Can access secondary email address but not primary email!
Message 4 of 10
Hi Jen,
Thanks for confirming - not sure what the solution is - only occurred today.
Checking - for some reason - BT may have farmed out e-mail services to US Amazon - and they have an issue with their servers. Log i have indicate possible anti-virus checking gone wrong with their servers.
Regards,
Shadders.
Message 5 of 10
Just started a thread about this, looks like a fault on  BTs side.
Message 6 of 10
I can get into sub email address OK but not into primary email!  Get message as below -
The page isn't redirecting properly
Firefox has detected that the server is redirecting the request for this address in a way that will never complete.
    This problem can sometimes be caused by disabling or refusing to accept cookies.
Message 7 of 10
Hi,
Firefox states :
I seemed to be working last night. But that was still January.
It does not work on the primary account which I access thru my bt etc then onto the sub accounts.  But I can access my sub accounts by using their e mail addresses and passwords.
I spoke to BT at the Indian call centre (which may as well be on the moon) and just got put thru the mincer as I expected, with excuses and delaying tactics. I realy do hate the whole concept of BTand its global dominence.
Any ideas... cos bt havent.
Brauntonboy
Message 8 of 10
Hi,
It would be good idea if BT published that there is a problem, and also stated that they are looking into it.
The failure to provide any response, one does not know if they are aware, or trying to resolve.
A forum is NOT the location to notify BT that there is a fault.
I have not called the fault people as others have done, as it has been indicated, that BT fail to actually recognise there is a problem.
Regards,
Shadders.
Message 9 of 10
I had this problem earlier today but it seems to be fixed now. I would try it again now !
Message 10 of 10
Hi,
Yes - seems to have been fixed now.
Regards,
Shadders.
