For some reason I cannot access the smart hub set up screens from 1 of my PCs, all that happens is the connection gets reset. All the other PCs can get the set up screens via 192.168.1.254 both wired and wirelesssly.
So far I have tried IE, Firefox
Installed a clean version of firefox
Reset the hub many times,
Removed the BT Home hub cookie.
rebooted the PC many times
The Pc works perfectly well for all other internet and lan functions so it's got to be said I'm a bit baffled.
All my phones, kindles also work OK though I'm getting a bit fed up with having to reconnect them everytime I do a reset, or is my Mrs who's giving me ear ache
Any suggestions?
Cheers
Solved! Go to Solution.
Any suggestions?
Cheers
Which version of Windows is the PC using?
Is there an error message?
You may find an error listed in the Windows event logs - if you know how to access these.
Have you gone through network troubleshooting procedures?
Which firmware version is the Hub at - assuming that another PC can access thie manager screen.
Thanks for the response
Windows 10 pro 2016, all upto date. This same version works on my Laptop and my Mrs's. Windows 8 also works OK
Just a generis Problem loading page, the connection was reset
Nothing in any log on the times when I try and use it. (using Nirsoft Event log viewer which shows all the logs)
Not sure which trouble shooter you mean.I've run the widows one and it didn't find anything
Howver everything else is working, browsing, pinging etc. I've tried switching Firewalls off
SG4B10002236, dated yesterday.
I suspect that the hub is OK seeing as all the other PCs can access it.
The only possible red herring is that prior to this I had plugged a USB drive into the hub and the PC that isn't working was connected at the time. None of the others were. Could this have corrupted something? who knows.
I've run SFC /scannow which didn't find anything.... does it ever?
I've tried deleting the PC from the hub and then reconnecting.
I've run driver booster to ensure all drivers are up to date
Cheers
Why are you having to re-connect your devices after you have done a reset? They should all just reconnect automatically to the Smarthub, assuming you have not changed the wireless passkey, when the Smarthub restarts after the reset.
If it is just a "soft" reset you are doing, have you tried a factory reset of the Smarthub by pressing a pin into the recess button on the rear for about 20 seconds. This should sort out any corrupted software/settings on the Smarthub.
I have changed the wifi pword to something I can rememer. The fact that it has changed after a reset implies a factory reset dosn't it, or am I missing something.
As I said, I now suspect the hub is hunky dory and some how my PC got screwed when I plugged in the USB drive.
I'm going to mess for a bit longer then I'll do a restore
Cheer
I don't have a Smarthub, but as far as I am aware it should be the same as all the Homehubs. A soft reset should not restore the wireless password to the factory setting and if you are not using the recess button, you are not doing a factory reset.
Cheer
As gg has posted, a factory reset will help, or at least eliminate further variants.
You have posted your responses, - thanks, it makes the situation clearer. I have a Smart Hub, and a factory reset was among the fixes which resolved a problem - not exactly the same as yours, but it now works reliably, even if no one else believes it.
Just to finally clarify.
I had done a factory reset, which made no diifference.
I deduced that the hub was actually OK as all the other PCS were OK, incidently I'm very happy with it.
The one PC had somehow got screwed just on this function. I suspect sticking the USB drive in the hub while this PC was on caused the problem but I'm not looking to try and recreate it.
I restored the PC back to a backup I took last week and it's now working perfectly again.
Thanks for the interest I'll close this.
