grumpy12
Message 1 of 8
Cannot download SmartTalk on my phone
I have a HTC Wildfire S running Android version 2.3.5 on O2. When I go into Google playstore there is no SmartTalk app to download. I have tried to download it from the internet but 1 attempt told me that my device wasn't compatable. Any ideas what the problem may be?
7 REPLIES 7
imjolly
Message 2 of 8
Re: Cannot download SmartTalk on my phone
I know it says android version 2.3.3 and up but can you update your phone firmware?  have you flashed the phone with no standard firmware?
grumpy12
Message 3 of 8
Went into update and confirmed I have the latest firmware for my phone. I haven't flashed the phone with non std firmware.
imjolly
Message 4 of 8
even though your firmware is ok there seems to be something else stopping you especially if you cannot get it from play store and trying a different route says your phone is not compatible
grumpy12
Message 5 of 8
Any suggestions what I could do then?
imjolly
Message 6 of 8
You can get the .apk file for android but not sure when you try and add to phone whether it will do nothing or it will work or cause a problem with your phone
Message 7 of 8
Thats a popular handset with a lot of fellow customers on here. As imj says, its almost as if the phone has been flashed [or maybe rooted] in the past.......
[Unless of course the app is already on/partly on the phone from a previous download - check the settings>applications - including the SD card].
If its a definate no to both, I'd walk into an 02 shop and let the staff have a go, as there sounds to be something adrift with the operating system of the phone.
AQ.
"Welcome to Royston Vasey - You'll never leave."
grumpy12
Message 8 of 8
Thanks for the suggestion(s). Think I will visit my local O2 shop when next in town!
