steve508
Message 11 of 38
Re: Cannot send e-mails from 3g smart phone using my @btinternet.com address
i use bt yahoo mail
hope you saw my earlier post-i found the settings
Message 12 of 38
@steve508 wrote:
btinternet is show up as the only account set up.
and no when i receive messages they do not disapear
oh just found incoming settings are pop3.btinternet.com (pop3 server)
outgoing settings show smtp server
mail.btinternet.com
port 587
shows unticked option "require sign-in"
Right, that makes sense.
You need to make sure that you use SSL, as the mail server needs authentication.
SMTP server
mail.btinternet.com
Port 465
SSL
Requires you to sign in
If that makes sense, as I cannot see the menu on your phone from here Smiley Wink
Message 13 of 38
If you want to be able to read mail on both your PC and your phone, without them being deleted from your PC, then IMAP is a better option.
Message 14 of 38
I use port 587 on my HTC to send btinternet mail
steve508
Message 15 of 38
hi changed port number and to ssl
ignored requires sign in and got message cannot safely connect to server(certificate hostname not useable for server:mail.btinternet.com)
so i assume need to sign in
then asking for username and password- is this to be the same as my bt yahoo settings in my home pc?
ps thanks very much for your time
Message 16 of 38
My HTC  uses smpt.mail.yahoo.com port 465
Message 17 of 38
Yes it is, its part of the authentication process, the settings should be stored.
steve508
Message 18 of 38
the setting was showing port 587 and security type "none" when i looked (i.e. when i left the shop and earlier this evening)
when i changed to port 465 i have two ssl security types- ssl or ssl (accept all certificates)
Message 19 of 38
SSL
Message 20 of 38
obviously there is more than 1 setting that works
my htc is  mail.btinternet,com
security none
port 587
btinternet sign in
