bdc
Message 1 of 14
Cannot send emails when on holiday
I can receive emails and access the internet but cannot send emails.
I use Outlook 2010.
I have followed all the advice from both BT and MS and synch incoming and outgoing emails but still no good.
Everything is fine when back home.
Advice please
13 REPLIES 13
Message 2 of 14
Re: Cannot send emails when on holiday
Try changing out going port to 587. Some ISP won't let you use port 25 failing that use webmail.
bdc
Message 3 of 14
Thanks for such a quick reply.
Webmail is no good when trying to reply to emails which require an attachment from my computer.
Can I use port 587 for all outgoing or just when away from my home hub - currently outgoing mail is on port 25??
Message 4 of 14
It should be OK for all out going but if a problem it is easy enough to change back.
Message 5 of 14
You can add attachments from webmail.
Distinguished Guru
Distinguished Guru
Message 6 of 14
As gg said, you can stay with port 587. For what it's worth, port 25 failed on my laptop ages ago and won't work on my Android phone. 587 is fine on both.
Distinguished Guru
Message 7 of 14
I use Outlook 2010.
Advice please
Hi. Welcome to the forums.
If you're on holiday, then typically the internet connection will be a different ISP, and hence you may not be able to use mail.btinternet.com since BTinternet may block access if not using a BT connection.
Changing the smtp settings to that of the connected ISP would also mean setting other items as the BTinternet email address wont be recognised.
Unless port 587 works with perhaps setting SSL/TLS in the settings, then the best option is webmail.
Message 8 of 14
I have used email in a few countries including USA, Canada and in Europe and apart from changing the port to 587 I have never had to change any other settings.
IanC
Recognised Expert
Message 9 of 14
Last time I tried that (a while ago, admittedly) BT didn't do that.
Distinguished Guru
Message 10 of 14
Hi (and to Ian).
Thanks for the update guys. I'm sure port 587 would work in most cases, as did using smtp.mail.yahoo.co.uk as the server - both "home" and away.
It does sometime depend on how the mail client wizard (or user) sets up the account details - or the information they've found etc.
