Hello
I have a small home network (2 PCs).
1st PC is my user everyday PC
2nd PC (Music) is a dedicated PC Windows 7 running Albumplayer software as a Music centre/player
When I was on TalkTalk I could connect to my 2nd PC from my Android phone & tablet via iTunes Remote, to control the Albumplayer software from the garden, enabling track/album selection/playing/changing etc.
The "remote" was paired via software link up with Albumplayer and pin code the same way as phone to phone.
Since moving to BT and a Smart Hub 2 Router, I can no longer connect my Android phone & iTunes remote to control my Albumplayer on the PC?
Can anyone help/advise me please
thanks
Carl
Try turning Smart Setup off.
If you have wireless connection issues, try turning off the 5GHz wireless on the smart hub, then see if your 2.4GHz wireless devices now connect.
Thanks Kieth, I'll try over the weekend. I have no issues with connecting other than this.
You may find this post helpful.
https://community.bt.com/t5/BT-Devices/Disabling-5Ghz-on-the-Smart-Hub-2/m-p/1992466#M169729
