Expert
Message 1 of 3
Cant watch BT Sport channels
Hi,
I do have the sport package including HD - when I select the cannel it says not available.
Anyone know why this is?
(I can see channels 507 - 512)
2 REPLIES 2
Expert
Message 2 of 3
Re: Cant watch BT Sport channels
Never mind fixed it.
I type the channel number in, when it loaded up the channel it said press ok to start setup.
Although I am now getting channel unavailable again, with an error message IPC6023 😕
OMG BT
Expert
Message 3 of 3
I keep answering my own QU's...
Apparently to be able to view the sport channels via the youview box I need to be 'hard wired' to the router.
However I am perfectly able to stream netflix via my console using the powerline adapters etc..
I get the above error message, so I tried to connect to the router directly, made no difference.
I then connected my laptop by wire to the switch that connects to the powerline adapter - it was able to load bt sport 1 and 2 almsot instantly with decent image quality.
Does anyone else have this problem?
I think its a little stupid for BT to provide powerline adapters, then tell me its not possible to use it with BT sport when actually they are easily fast enough to hold a solid connection and load large files..
I do this trying to stream content via netflix etc..
Im barely 3 metres away, but due to the locations of the TV and router, I do not want wires to be trailing around the TV room.
ANyone got any ideas?
Thanks in advance
