Message 11 of 25
Re: Capped Broadband - help with my obsession pleaseeeeeeee!?
I have an (older) cable which has RJ11 on one end and the large "phone" type connector on the other - but I will take advice and just use a brand new filter with the same cable tonight when I get home
Message 12 of 25
You can't use that cable with a filter, you would be plugging it into the filtered part rather than the unfiltered. Try with a filter and RJ11-RJ11 cable. The problem might be the cable.
Message 13 of 25
Oh ok, will give it a go.  I have a brand new filter and cable from when I phoned BT and seemingly the best way to get me off the phone was to pointlessly send out a new Smarthub 1 to replace my perfectly fine Smarthub 1...
Might actually come in useful!
Will report back later.
I'm also trying to source (borrow) a 3rd party modem/router to mess with too.
Message 14 of 25
Don't make too many disconnections/connections or DLM will take action and reduce your speed. Definitely no more than one in an hour.
Message 15 of 25
careful to many disconnection as you try different thing may result in DLM taking action and reducing your connection speed and increasing your noise margin
Message 16 of 25
Haha yes jinxed posts.
I have just got word that I also still have a working openreach modem (the one that used to get installed seperately before the homehub 5 i think?).  This obviously gives me more options when it comes to routers. (If I switch both I'll do them both at the same disconnect point!)
Do you guys actually see many people see improvements going back to the separate kit? The smarthub was always known as decent but it's fairly old now.
Message 17 of 25
if smart hub old now then modems are ancient😄
Message 18 of 25
Fair point!
To be honest, I don't need need wifi improvements.  Everything is hard wired into the smart hub anyway. I've honestly read so much for days now, but something about bufferbloat on Stadia/streaming services etc.
I just need the fastest possible modem and fastest possible router.
Damn just found out the modem I have is the ECI version 😞
Message 19 of 25
so is your cabinet ECI
Message 20 of 25
Yes, but the HG612 version can be easily hacked to enable the web UI... I'm comfortable with that, less so soldering the ECI version!
