Message 1 of 20
Capped download sync speed
Hi
My download speeds have been decreasing over the last 18 months. Used to get a stable 40ish Mbps. I have noticed recently however that the last few hub restarts over the course of a few week (we had some building work done which required the power to go off) that the download sync speed would be set at exactly 30.00 Mbps - like it is being capped! I have been on BT infinity for a number of years now and pay for the top speed available (76Mbps). Can anyone help? Why does this appear to be capped? How can I restore my speed (for what I am paying for).
This isn’t about what the service estimates I ‘should’ get. As I mentioned I used to get a very stable 40Mbps+.
19 REPLIES 19
Message 2 of 20
Re: Capped download sync speed
Which BT Home hub do you have?
Message 3 of 20
Hi. I have Home Hub 6
Message 4 of 20
Can you please  post the information from the smart hub, using this link.
http://192.168.1.254/0000012803/gui/#/technicalLog/information
Message 5 of 20
Product name: BT Hub 6A
Serial number: +084319+NQ61823534
Firmware version: SG4B1000B316
Firmware updated: 23-Jul-2017
Board version: 1.0
Gui version: 1.64.0
DSL uptime: 0 Days, 0 Hours 43 Minutes 27 Seconds
Data rate: 6.07 Mbps / 30.00 Mbps
Maximum data rate: 6125 / 38694
Noise margin: 6.1 dB / 6.3 dB
Line attenuation: 25.4 dB
Signal attenuation:
VPI / VCI: 0/38
Modulation: G_993_2_ANNEX_B
Latency type: Fast Path
Data sent / received: 48 MB Uploaded / 231 MB Downloaded
Boot loader: 7.33.1.
Message 6 of 20
Your noise margin is 6.3dB, so there is no room for improvement at the moment. Your line may not support any faster than what you are getting.
Is there any noise on your phone calls? Dial 17070 and select option 2, there should be no noise between the announcements.
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Message 7 of 20
There doesn’t appear to be any noise on the line. The issue is that I have had much higher stable speeds before and also I have never seen the sync speed at exactly 30.00Mbps - especially after a restart, it has always been slightly different each time leading me to think I am being capped for some reason. Could restarting the ‘learning’ process help as if I were a new customer ?
Message 8 of 20
Why are you paying for Infinity 2, as you are never going to get that speed?
Your actual connection speed would reduce over time, due to crosstalk from other customers connected to the cabinet
Your max data rate is showing as about 38Mbs, but that will vary depending on line conditions, and you would not normally connect at that speed, as the connection coulld become unstable.
As long as you are within Range A on the broadband availability page, then nothing can be done.
Restarting or disconnecting the home hub is likely to make things worse.
Message 9 of 20
I didn’t mean restarting the hub, but more the 10 day line learning process that occurs with new customers. I paid for the higher amount as at the time I did have a speed higher than the lower affinity speed cap.
Thanks for for your help anyway. I might have to try a different provider as this is becoming less and less worth the money as time goes on.
Message 10 of 20
enter your phone number andpost results  remember to delete number http://dslchecker.bt.com/adsl/adslchecker.welcome
unless you move to cable all ISP s the same connection from the cabinet to your home so you may get a better price but connection is the sameone currently supplied by openreach
are you using the test socket to see if that helps?
it's probably with the work you have had done and power to router going off/on that has affected your connection speed
