Message 1 of 5
Casting to Sony tv
Hi I upgraded to a new by smart hub 6 and can no longer cast bt sport to my tv. I can chromecast from YouTube fine so it’s not the network.
Any ideas? Thanks
4 REPLIES 4
Message 2 of 5
Re: Casting to Sony tv
At a guess, you need to run setup on your Chromecast again and tell it to connect to the new SSID
If you found this post helpful 🙂 then please let me know by clicking the thumbs up button below. On the other hand, if you found it unhelpful 😞 then please let me know by clicking the thumbs up button below . 😄
Message 3 of 5
Tried that without any joy. It seems to be the router. I plug in a home hub 5 and it works fine
Message 4 of 5
Have you tried logging on to your smarthub to check that your chromecast is listed as connected? If it is then note the ip address and try pinging it.
Message 5 of 5
It's  an inbuilt one in the Sony android tv. It all casts fine from youtube and other areas. It's just the by sport one not even showing through the app. I never had this issue with the homehub5.
I have tried turning off the smart access on the router but still nothing.
thans for your help so far
