Message 1 of 9
Catch up player missing on BTTV
When I got to but player the catch up isn't in the list I've reset I've done updates and it's still missing from the list
8 REPLIES 8
Moderator
Moderator
Message 2 of 9
Re: Catch up player missing on BTTV
Hi @Mrbrymel I have moved this post to create your own thread as that is the best way to get help.
We will be happy to help you with this if you send us your details. You can contact us by clicking on my user name and selecting contact the mods. It will take a few days before we can get to you but once we do we will take ownership until the fault is fixed.
John
Message 3 of 9
is this the catch up option in the BT player?
Message 4 of 9
Yes mate it was there one day now gone I've done all updates reset u name it I done it
Message 5 of 9
I found it to be buggy. Just go in the first time after the box is on and is is not there. Exit the apps go back in and catch up is there. Also works differently if you go through players and app or the remote button
you go figure
Message 6 of 9
It was yesterday then when I exited the bt player went back in and it's disappeared again it's driving me mad only so many times I can reset
BT TV Expert
Message 7 of 9
Hi @Mrbrymel
Sorry you are having issues with your BT TV services.
If you send me your telephone number via PM, I'll take a look into the issue for you.
Thanks,
Gemma
Moderator
Moderator
Message 8 of 9
Hi @Mrbrymel The catch up player should now be working OK. I called earlier to check with you but wasn't able to contact you. Please post back and let me know if this is now working OK for you.
Cheers
John
Message 9 of 9
Catch up is there thankyou so oooo much
