Message 1 of 14
Cctv sv3c camera
Hello I hope you can help
we have bought a SV3C CCTV Camera unfortunately it will not connect it to our bt smart hub2
which has replaced our old bt router
In the instructions it says the camera only pick up 2.4ghz  we were informed that the bt smart hub2 has a sliding scale from 2.4 to 5ghz so thought it would be ok any help would be much appreciated how to install the camera on BT smart hub2
13 REPLIES 13
Message 2 of 14
Re: Cctv sv3c camera
The first thing to do is to turn off Smart Setup on the hub, this causes untold problems.
https://www.bt.com/help/broadband/what-is-smart-setup-on-the-bt-hub--how-can-i-turn-it-on-and-off-
The Hub 2 has 2 wifi bands, 2.4Ghz and 5Ghz but they have the same name (SSID). Whilst devices that are only 2.4Ghz should have no problems, some devices do seem to struggle with the 2 bands having the same SSID. Temporarily turning off the 5Ghz band until the device has connected and then turning it back on again afterwards seems to work for many devices that have the problem.
Its not clear from your post if the camera worked OK with the old hub.
Message 3 of 14
Thank you
its a new camera and a new smart hub2
old camera worked fine. Can I turn off smart setup via my iPad?
Message 4 of 14
Yes if you select desktop site on the browser rather than mobile site for the hub manager page.
Message 5 of 14
Many thanks for your help will let you know if it works
Message 6 of 14
Message 7 of 14
I followed instructions switching smart setup of
Unfortunately still can’t connect cctv camera
Message 8 of 14
Did you try turning off the 5Ghz wireless temporarily?
Message 9 of 14
Hi
No just turned off smart setup
Not sure where you turn off  5Ghz
Message 10 of 14
Advanced settings > Wireless
