RedGT
Message 1 of 8
Change data plan?
Was thinking of going from 2G a month to 20G. Can this be done?
7 REPLIES 7
Damien1
Message 2 of 8
Re: Change data plan?
Yes you can move up at any time just give bt a call on 150
pottyperson
Distinguished Guru
Distinguished Guru
Message 3 of 8
But be aware that BT don't allow tethering. 20GB seems an awful lot to use on a mobile.
RedGT
Message 4 of 8
Not really when your downloading podcasts.
pottyperson
Distinguished Guru
Distinguished Guru
Message 5 of 8
There will always be exceptions but the general consensus in the link I posted is that 20GB on mobile is not much use without tethering.
23prince
Message 6 of 8
Are you 100% sure about that? I have experience to challenge what you say.
20GB might seem an awful lot to use for you but it's not for others and clearly the reason why it's on offer.
I have a mobile coming to an end of Three and I do 40-50 every month on the handset
gg30340
Message 7 of 8
BT's Terms & Conditions prohibit "Tethering" See Link.
http://www.productsandservices.bt.com/consumer/terms/mobile-service.html
Prohibited use
  1. You must not allow our service to be used:
  1. for machine to machine communication (this means the communication between two or more machines without a person); or
  2. to create your own personal hotspot which provides internet access to other devices which may be used by yourself or others (this is sometimes known as 'tethering'); or
  3. to route, re-route, forward, or divert calls and text messages for commercial gain (this is sometimes known as being a 'GSM gateway' or a 'SIM gateway'), or for any other purposes other than personal use; or
  4. to make offensive, indecent, menacing, nuisance or hoax calls, or to cause annoyance, inconvenience or needless anxiety; or
  5. in any manner which is otherwise unlawful.
It is also listed in their sales pages under the FAQ section > BTMobile > The Legal Stuff > BTMobile > BTMobile Sim Only Plans
BT Mobile SIM Only Plans
Discounted price for BT broadband homes (excludes business). 12 month minimum term. Payment is by direct debit and subject to credit status. UK calls to UK landlines (starting 01,02,03) and UK mobiles, standard UK texts and data within the UK. You cannot share your data connection with other devices. Speeds vary by location, coverage and demand. One minute minimum call charge. 08 numbers cost up to 38p/min, calls to 070 cost up to 92p/min. 0800 numbers and calls to voicemail included. Early termination charge may apply if you stop your service in the first 12 months, see bt.com/terms. For BT wifi see: www.btwifi.com. Compatible phone needed, may need unlocking.
pottyperson
Distinguished Guru
Distinguished Guru
Message 8 of 8
See gg's reply and the follow-up to my first post.
You've missed the point. I was just sounding a warning to the OP, that's all. I never said that nobody uses 20GB on a mobile, but the fact is that many of those interested in that plan want to use tethering. That's what the argument in the linked thread is all about, as you'll see if you read it.
