mjones494
Message 11 of 34
Re: Change of latency + dropouts
The wiring already looks like the final result 😕
Message 12 of 34
then you have some bad connection somewhere in your internal extensions
Message 13 of 34
have you removed the bell wire from terminal 3 of all your sockets ??
mjones494
Message 14 of 34
Its just strange the other day it was fine, unplugged in and put it straight back nothing was changed etc, perhaps the line was busy so it screwed itself up will have a better look later
Message 15 of 34
the socket could have a faulty connection like an intermittent connection it needs looking at carefully
mjones494
Message 16 of 34
Ive unplugged the skyboxes
Downstream6,368 Kbps
Message 17 of 34
Electrical stuff goes faulty.
Ever had a fuse blow? Or something just stopped working? This stuff happens.
Happened in my old house, worked fine for years on an upstairs connection. Came home one day and nothing. Into the test socket and back to full speed, back upstairs and nothing.
Message 18 of 34
has the sky box got a filter fitted that sounds like the problem
mjones494
Message 19 of 34
There are 3 sky boxes, none of which have filters.
Still can't reach the max 8000+ i was syncing at the other day
Message 20 of 34
presumably not connected to the phone line if they don't have filters either that or filtered faceplate  must have filters if connected to phoneline
