mjones494
Message 21 of 34
Re: Change of latency + dropouts
I'm at 6000 downstream, how long will it take for my profile to go up its currently at 2.5 megs
Message 22 of 34
anything up to 3/5 days provided connected 24/7
mjones494
Message 23 of 34
Can i request to get changed to FAST, since it used to be excellent on that? or i should i wait a few days?
Message 24 of 34
I would get my connection stable and sorted before making any change to fast which may make your connection more unstable.  no problem asking for change once connection ok
Message 25 of 34
You'll get the 8meg sync when your line has been stable and the SNR is reduced. You'll also see that interleaving will be removed once DLM is happy your line is stable and error free.
mjones494
Message 26 of 34
Just plugged back one of the sky boxes in, connection dropped and started syncing at 4000 straight away 😕
Message 27 of 34
with a filter?
mjones494
Message 28 of 34
Nope, they've never had any in and they use to be fine, should i use one?
Also 2 are sky hd if that makes a differnce
Message 29 of 34
if you don't have a filtered faceplate on the master socket then anything connected to the phone socket must use a filter
mjones494
Message 30 of 34
oh, well i use a filter to the hub, but the sky boxes have been fine, guess i need to go buy some, where abouts can i get them from?
