lancashiretea
Message 1 of 7
Changing IP address on BT HUB 3.0
Hi all,
I want to change my IP address for security reasons. I can't seem to do it with BT HUB 3.0.
Is there any way around this? Ideas much appreciated - thank you very much!
Miranda
6 REPLIES 6
Devon_Dave
Distinguished Guru
Message 2 of 7
Re: Changing IP address on BT HUB 3.0
Is this the public one or the private range on your hub?
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
lancashiretea
Message 3 of 7
The public one - sorry about that.
Thank you very much.
DS
Distinguished Guru
Message 4 of 7
Powering down the hub for about 5 mins should allocate you with a new IP Address.
-+-No longer a forum member-+-
lancashiretea
Message 5 of 7
thanks for the reply.
i unplugged the hub for half an hour, but when i go to system prefs/network in my mac, the IP address it gives there is still the time. am i looking in the right place? or is that perhaps the private IP mentioned by the first reply?
many thanks,
miranda
imjolly
Message 6 of 7
sounds like your MAC ip address allocated by your router not the external IP which will change as advised
Devon_Dave
Distinguished Guru
Message 7 of 7
The hub will give out a private IP address in the range of 192.168.1.54 to 192.168.1.237
The public range could be about this, mine currently is 86.171.236.xxx
