mjones494
Message 1 of 3
Changing Latency
Created an article about a month and a half ago after my connection screwed up, but its been sorted for a few weeks and was wondering how i contact the mods into getting changed from interleaved to fast?
ADSL line status
Connection Information
Line stateConnected
Connection time17 days, 15:01:00
Downstream8,128 Kbps
Upstream448 Kbps
ADSL Settings
VPI/VCI0/38
TypePPPoA
ModulationG.992.1 Annex A
Latency typeInterleaved
Noise margin (Down/Up)10.6 dB / 27.0 dB
Line attenuation (Down/Up)29.3 dB / 15.0 dB
Output power (Down/Up)12.4 dBm / 1.8 dBm
Loss of Framing (Local/Remote)0 / 0
Loss of Signal (Local/Remote)0 / 0
Loss of Power (Local/Remote)0 / 0
FEC Errors (Down/Up)31039 / 373
CRC Errors (Down/Up)30591 / 290
HEC Errors (Down/Up)306141 / 258
Error Seconds (Local/Remote)10570 / 446
2 REPLIES 2
Message 2 of 3
Re: Changing Latency
this is a link to the mods remember going to fast path can make your line more unstable  unless you are an ardent gamer  i would reccomend staying on interleaved
http://bt.custhelp.com/app/contact_email/c/4951
they normally reply by email or phone directly to you within 3/5 working days
They are a UK based BT specialist team who have a good record at getting problems solved
mjones494
Message 3 of 3
Yes i am a gamer it used to be on fastpath and was fine then, thanks for the help 🙂
