cath-needham
Message 1 of 16
Changing from ADSL to ADSL 2+
Hi I've recently moved to a new house and the connection speed is terrible and unreliable. I've noticed that we are only on ADSL not ADSL 2+. The results from the DSL test show that this is available on our cabinet and should be much quicker than we currently have. Would it be possible to be moved onto ADSL 2+ at least to try it.
Thank you.
Telephone Number on Exchange PENISTONE is served by Cabinet 24
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date     Left in JumperOther Offerings     Availability Date       Premise environmentStatus
WBC ADSL 2+Up to 15--8.5 to 18.5Available--------
ADSL MaxUp to 2--1 to 3Available--------
WBC Fixed Rate2----Available--------
ADSL Multicast------Available--------
Bridge TapU
VRI--
NTEFaceplate--
Last Test Date01-01-2017
1. Product name:BT Home Hub
2. Serial number:+068343+NQ41422751
3. Firmware version:Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 05/07/17
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 08:52:41
6. Data rate:448 / 2144
7. Maximum data rate:1068 / 2272
8. Noise margin:19.0 / 9.4
9. Line attenuation:31.5 / 57.1
10. Signal attenuation:31.5 / 55.1
11. Data sent/received:915.7 MB / 34.6 GB
24. VPI/VCI:0 / 38
25. Modulation:G.992.1 Annex A
26. Latency type:Interleaved
27. Software variant:AA
28. Boot loader:1.0.0
15 REPLIES 15
Keith_Beddoe
Message 2 of 16
Re: Changing from ADSL to ADSL 2+
Welcome to this user forum.
I have asked a moderator to provide assistance, they will post an invite on this thread.
They are the only BT employees on this forum, and are based in the UK.
cath-needham
Message 3 of 16
Thanks Keith for bringing it to their attention and for the quick reply
imjolly
Message 4 of 16
There is something wrong either with the estimate from dslchecker of the attenuation shown by the router which at 57db would only give adsl2 speed of about 3.5mb
are you using the test socket with a filter
cath-needham
Message 5 of 16
Hi,
Yes it's connected directly to the test socket with a filter.
Sadly even a adsl2 speed of 3.5Mb would be alot better that we get now. It barely gets to 1Mb
Keith_Beddoe
Message 6 of 16
Do you get dial tone on your phone, and is the line quiet?
cath-needham
Message 7 of 16
Yes to both
imjolly
Message 8 of 16
Your router shows a connection speed of 2mb not 1mb. The 3.5mb I mentioned is connection speed not download speed
cath-needham
Message 9 of 16
Ok didn't realise there was a difference between download and connection speed. The 1Mb was from the bt speedtest website, it is currently showing 1.01 with the router saying connection speed of 1.3
imjolly
Message 10 of 16
You can see the data rate of 2mb in hub stats.
