Ajkennedy
Message 1 of 17
Changing from sky fibre to bt infinity
Hello.
I currently have sky fibre pro and I'm considering moving to bt infinity 2. Just wondering if anyone else has changed from sky to bt and if so has there been any problems .
Thanks in advance
16 REPLIES 16
Webby
Message 2 of 17
Re: Changing from sky fibre to bt infinity
Many people have done it, vast majority have no problems.
By proxy, on a forum such as this you might find a higher percentage of people have had a problem, but that's because people who don't have a problem, don't tend to come to a forum to say everything is working fine 🙂
Keith_Beddoe
Message 3 of 17
The only issue could be if there are no spare ports in the fibre cabinet, as your existing Sky fibre connection will be ceased, and given to the next person on the waiting list, which would not be you.
Check before you move, to see if the cabinet is showing "waiting list" If it is, then you will lose your fibre connection.
In order to find out what services and speed range you should be getting, please enter your phone number into this form.
Broadband availability checker
Please remember to edit out your phone number before you post the results.
Ajkennedy
Message 4 of 17
Hi
Had a look on the availability checker and it comes back with no data available for phone number probably because it is not a bt line. I have entered my address and it comes back saying fibre is available
Keith_Beddoe
Message 5 of 17
Then you should be fine if the address checker shown that the cabinet is not full.
Ajkennedy
Message 6 of 17
Ok thanks for the reply. Does anyone know if the bt smart hub has better wireless range than the sky q hub ?
pippincp
Sage
Message 7 of 17
If I were you I'd buy a 3rd party router.
adly
Message 8 of 17
As someone in the process of such as move I would personally advise against such a migration, unless you're getting an insane deal. Ordering was a nightmare and still isn't resolved, customer services are HORRENDOUS and make Sky's service appear near perfect, and the Smart Hub is an absolute joke compared to any of Sky's hardware.
The only saving grace is the mod team who genuinely try to help but are very busy picking up the pieces dealing with the incompetence of the rest of BT.
Just my 2p worth. 😉
mikeatsg
Message 9 of 17
I agree with adly. Do NOT change anything you don't have to. The connections are supplied and serviced by the Openreach monopoly, not BT, and so you will still end up with the same provider. The OR engineers are very good but the BT back office function is totally broken. It is utter chaos in there. I am just now coming on stream with a second line ordered from BT Business in December. Just to start the ball rolling they automatically cancelled the order twice before getting on with it.
Don't even think about changing just to save a few quid. You'll regret it. As Webby says, the people who appear here are those with problems - and there are lots of those.
Keith_Beddoe
Message 10 of 17
Try looking at the number of complaints on other ISPs forums, you will find the same complaints. The advantage on this forum is that you can get help if you need it, via the forum moderators, if it cannot be resolved by forum members.
