Message 11 of 12
Re: Changing my BT Smart hub 2 -- I need serious help
Good plan.
Message 12 of 12
Hello, just wanted to say thank you for the help last week. I got a DSL-AX82U and after a lot of learning regarding the setup to make things work and a couple days of pulling my hair out, it's finally working properly and smoothly (fingers crossed)
I'm sure I'll be back if it stops!
Thank you @licquorice
Will mark this as solved
