Stewadg
Message 1 of 8
Changing to infinity
I'm moving from ADSL to infinity and have change date of tomorrow. Have received smart hub in post. I was expecting engineer visit, but when I checked with BT they said no need, just plug in kit they've sent and I'm good to go.
I thought I needed an engineer?
Can anyone confirm if this advice is correct?
7 REPLIES 7
gg30340
Message 2 of 8
Re: Changing to infinity
You do not get an engineer visit. Just plug it in the same as the old one.
Stewadg
Message 3 of 8
That's what the very helpful lass on the phone said. I was amazed, after reading all the stuff on here about moving master sockets etc.
gg30340
Message 4 of 8
You will only get an engineer visit if there is a problem after you have connected up. In the vast majority of self installs there is no problem and an engineer visit to just plug in the hub would be a waste of money and resources.
Stewadg
Message 5 of 8
Can I ask another?
Currently I have extension cable running from my master socket to front room, where my current router is.
When infinity starts will I still be able to use same setup to have smart hub in front room.
Length of extension is about 6m, and the street cabinet is literally outside my front garden, so total length of copper between me and fibre only about 20m max.
Webby
Message 6 of 8
At that distance from the cabinet, I doubt it will have any impact.
Especially if you went for Infinity 1, but even on Infinity 2 it's unlikely, unless it's terrible quality and or damaged.
Stewadg
Message 7 of 8
Many thanks, that's very helpful.
Previous experiences with BT have tended to leave me slightly paranoid about their ability to deliver!
Webby
Message 8 of 8
Wouldn't matter which ISP you used. The connection from the cabinet to your modem is carried over the same Openreach network.
