Message 1 of 4
Checking address for landline availability
I purchased a second home in Dec 2020 but can't visit until 12 April due to COVID rules. How can I find out whether it has a landline and whether it is active without visiting?
3 REPLIES 3
Message 2 of 4
Re: Checking address for landline availability
@davidhowes36
Its not possible to do that, however if you use the online ordering page, it should give you some idea whether there is an existing BT Retail service.
Its a good idea to place an order now, so that service will be available when you need it.
Place an order for a line only using this link - https://www.bt.com/landline/deals
Message 3 of 4
You may still have a line into the house but I very much doubt is still active as the previous occupier would have had the line stopped. If not they would still be paying for it.
(If I have helped you in any way please click the thumbs up. Thank You)
If I have solved your Issue please click the "Mark as accepted solution" button.
Message 4 of 4
Wouldn't it be possible to simply contact the previous owner,  albeit via the estate agent if necessary,  and just ask them what the situation is as regards the existence of a landline or not?
