kket
Message 1 of 6
Cisco Router behind BT Home Hub - VPN/Telnet
Hi everyone,
I am having troubles with the Home Hub router's (I think) inbound/outbound traffic. Could anyone shed me some light please?
Here is my setup:
What I am trying to achieve is to allow external PCs to VPN inside to my Cisco router (VPN server already setup tested and working in internal network).
Here is the config files for my Cisco router:
Current configuration : 1382 bytes
! Last configuration change at 12:20:34 UTC Fri Jan 3 2014
version 15.1
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname Router
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication ppp default local
aaa session-id common
dot11 syslog
ip source-route
ip cef
no ipv6 cef
multilink bundle-name authenticated
vpdn enable
vpdn-group KNS-VPN
 ! Default PPTP VPDN group
 accept-dialin
  protocol pptp
  virtual-template 1
 l2tp tunnel timeout no-session 15
crypto pki token default removal timeout 0
username ket password 0 cisco123
redundancy
controller E1 0/0/0
interface FastEthernet0/0
 ip address 192.168.1.254 255.255.255.0
 duplex auto
 speed auto
 no shutdown
interface FastEthernet0/1
 duplex auto
 speed auto
 Shutdown
interface Virtual-Template1
 ip unnumbered FastEthernet0/0
 peer default ip address pool defaultpool
 no keepalive
 ppp encrypt mppe auto
 ppp authentication pap chap ms-chap
ip local pool defaultpool 192.168.1.10 192.168.1.20
ip forward-protocol nd
no ip http server
no ip http secure-server
disable-eadi
control-plane
line con 0
line aux 0
line vty 0 4
 transport input all
scheduler allocate 20000 1000
end
On the port forwarding side on BT Home Hub, I have created a setting for it which is (1723) for PPTP and mapped to 192.168.1.253 which is the IP of fa0/0's Cisco router.
What I have tested so far is all in internal network meaning that traffic never go out the external network.
  • Created a public IP 10.10.10.1 on fa0/1
  • A computer with 10.10.10.2 connected to fa0/1
  • Computer ping fa0/1 fine
  • Computer has correct VPN configuration setup
  • Computer VPN fine and got the right pool IP address from the router (In this case 192.168.1.10)
  • Computer pings fine to gateway of internal IP address 192.168.1.253
To realistically test it out I have put this setup in a working environment with a broadband router. A picture shown on top of the post illsturate the topology. The steps what I have done it:
  • Cisco router used a straight through cable wired to BT home hub
  • Cisco router (192.168.1.253) pings fine to BT home hub router (192.168.1.254) and pings other networked devices fine connected wirelessly to BT home hub.
  • BT Home hub has correct port forwarding PPTP settings (TCP: 1723), I have also tried to use the pre-defined settings from the drop-down list called PPTP server/VPN.
  • Firewall disabled
I'm just running out of ideas, anyone can help me on this I will be apperciated.
Thanks!
5 REPLIES 5
Keith_Beddoe
Message 2 of 6
Re: Cisco Router behind BT Home Hub - VPN/Telnet
Are you a business user?
kket
Message 3 of 6
No I'm not, I'm just trying to learn and study Cisco networking but I can't overcome the BT home hub issue...
Keith_Beddoe
Message 4 of 6
Its probably a bit too complex for this forum, unless you can find someone with a similar setup. You may like to read the BT Business forum, and see if anyone had done anything similar.
kket
Message 5 of 6
Found the problem! Router did get packets, but packets get lost on the way back to the client as I did not set the default ip gateway for the cisco router!
What I did is:
ip route 0.0.0.0 0.0.0.0 192.168.1.254
Telling all the packets to return back to the broadband router! If packets does not know the destination then the packets get forwarded to the broadband router and the broadband router or ISP network handles to rest!
urssunil4u
Message 6 of 6
hey bud,
you doing CCNA,
heres what you have to do....
you need NAT and ACL to allow all your inside traffic. and also you need DNS server on router so it will convert IP addresses into names.
one very important thing isget you NAT correct with overload. if you still interested ask me i will shoot config...
