Message 11 of 27
Re: Cold weather rendering my infinity 2 unusable
1. Product name:BT Home Hub
2. Serial number:+068343+NQ42582157
3. Firmware version:Software version 4.7.5.1.83.8.173.1.6 (Type A) Last updated Unknown
4. Board version:BT Hub 5A
5. VDSL uptime:0 days, 04:05:22
6. Data rate:15921 / 65296
7. Maximum data rate:15750 / 73673
8. Noise margin:5.8 / 6.0
9. Line attenuation:0.0 / 19.3
10. Signal attenuation:0.0 / 19.4
11. Data sent/received:259.5 MB / 183.0 MB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
Those are the stats. As i said i've had the same engineer at my home 3 times and he's confirmed there is nothing
wrong with my line or any of my equipment ( although bt sent me a new hub for some reason weeks ago and it solved nothing)
Message 12 of 27
can you run btspeedtester and when first test completes run diagnostic test and post results
btspeedtester
Message 13 of 27
I click further diagnostics & some kind of test runs then i get :
HTTP Status 500 -
type Exception report
message
description The server encountered an internal error () that prevented it from fulfilling this request.
exception
java.lang.IllegalStateException: Cannot forward after response has been committed
	org.apache.struts.action.RequestProcessor.doForward(RequestProcessor.java:1078)
	org.apache.struts.action.RequestProcessor.processForwardConfig(RequestProcessor.java:396)
	org.apache.struts.action.RequestProcessor.process(RequestProcessor.java:232)
	org.apache.struts.action.ActionServlet.process(ActionServlet.java:1913)
	org.apache.struts.action.ActionServlet.doPost(ActionServlet.java:462)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
	javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
note The full stack trace of the root cause is available in the Apache Tomcat/6.0.16 logs.
Message 14 of 27
just did it again and got
Home Image not loadedTesting Image not loadedSystem Error Image not loaded
FAQ
null
You appear to have not logged on as speedtest@speedtest_domain. In order to run the next test you should login as speedtest@speedtest_domain.
Please wait while you are redirected..
Distinguished Guru
Message 15 of 27
Are your problems when using wifi or wired ethernet?
If not, I'll try again 🙂
Message 16 of 27
Both. I have a laptop and set top box with wired connections and my phone using wifi.
Distinguished Guru
Message 17 of 27
Can you try this Speedtest please, to see if it shows the problem? http://www.thinkbroadband.com/speedtest/speedtest2.html
Message 18 of 27
Distinguished Guru
Message 19 of 27
Ouch. so you need the mods to ask Openreach to change the backplane
Message 20 of 27
Yeah, thats what the engineer told me. He said the fault was either the card or backplane. Card was changed and the problem still persists so only the backplane remains. Indian tech support though are adamant the problem has been fixed
and wont listen.
up until you just said backplane i could have sworn he said backplate Smiley Very Happy
