Message 1 of 7
Communication disaster
How do you get an engineer.
After several failed attempts we booked an engineer  on-line to repair a fault. We received a confirmation email from BT confirming our booking date and time.
Date and time has passed and no BT engineer has shown up.
On MyBT we click on track a fault to find this message that states: " There are no faults to display for this account"
How to get a BT engineer, pleae help.
6 REPLIES 6
Message 2 of 7
Re: Communication disaster
For faults you can call 0800 800 151. then follow the prompts.
Message 3 of 7
It would be Openreach not BT Retail that would fix your fault.
You should be able to track it online, unless it never made it onto the fault reporting system.
Message 4 of 7
the system does not work, it says No faults, which is quite clearly wrong, so NO you cannot track on-line.
Message 5 of 7
You must understand, the previous debacle that was 151 means no one calls anymore, it was a disaster area. Why should I spnd my hours trying to carry out a simple task of reporting a fault. 151 is nothing but stressfull call deflection.........
Message 6 of 7
If you don't do it, nobody will do it for you, so your options are contact BT or live with the issue.
Message 7 of 7
To be honest, over the last years BT has become such a difficult compay to work with, I am passed caring if my landline works or not. One thing is for certain, I am not going to waste my time and money trying to deal with a Company that appears to be out of control.
The sooner BT is broken down and sold off,  and re-establishes itself as a Customer orientated business the better.
