apulmax
Message 1 of 120
Complaint - 5 months on and BT have no clue what they are doing. Ofcom/BBC Watchdog here I come!
I have come to the end of my tether. I can not deal with the stress BT have given me by their incompetence and lack of customer care. I reported my broadband losing upstream connection way back in July 2012. I am too tired to sit here and wear my keyboard out typing my life history with BT. In a nutshell since July, I have been having broadband faults and Telephone line faults. In 5 months I have only had 3 weeks of uninterrupted service which is totally unacceptable.
I am appalled by the way the helpdesk in India answers the phone....."Hello, what is your problem"
Where has the common courtesy gone by announcing "Hello BT Helpdesk here, how can I help you" or is that too much to ask?
Anyway, reading the complaints on here, it is all too familiar that other customers are getting treated the same way. Calls always getting cut off and though the helpdesk person has my number, they never ring back!! Come on BT what's your game?
The other thing is that I am always fed a load of bull about what's really gone on. Hey BT I used to be a telephone engineer in the 80s so don't feed me with a load of garbage, I am not supposed to understand their so-called rubbish they tried to feed me. I am more qualified than all the helpdesk people put together. I was also Technical Consultant to the CEO of BTOpenworld, with 23 years of IT experience. I am an expert in Broadband systems as well.
BT knows I can not go to their competitors like Virgin, TalkTalk, Sky etc as they all use BT's equipment (no cable here) and I will be no better off. But hey, I am tempted by Satellite Broadband and 4G which will give me better bandwidth than the puny 3mb that I get when it does work.
I could be your Top Level troubleshooter visiting customers premises and sorting their ongoing problems that no one in BT seems to care about, but then you wouldn't pay me enough!
Now I have got that offloaded, I will be contacting BBC Watchdog and Ofcom/ombudsman for the total incompetence on BT's behalf, oh I forgot to mention............I had exactly the same problems in 2011 and that took months of getting nowhere, so I complained to the ombudsman and they found BT guilty of a list of failings and promised it would never happen again. Well guess what? It has and I am going to complain to them again and get some necks on the line!
Bt has had long enough to sort this out and still has the cheek to bill me each month....Pah
Mods, you can get my case details up on your system, but you will need 3 hours to read through them as I have only touched the tip of the iceberg on here.
Good luck BT, you'll need it!!!
119 REPLIES 119
DavidM
Moderator
Moderator
Message 2 of 120
Re: Complaint - 5 months on and BT have no clue what they are doing. Ofcom/BBC Watchdog here I come!
Hi Apulmax,
Welcome to the forum and thanks for posting. I’ll be happy to look into this for you if you wish. Drop me an email with the details. You’ll find the “contact us” form in the about me section of my profile.
Cheers
David
apulmax
Message 3 of 120
Was promised a phone call this morning between 8.00 and 10.00 from 2nd level support, did I get one?........NO!!!
john46
Message 4 of 120
Hi Have you contacted David M as he suggested he will be able to get your problem resolved for you In case you cannot find it this is a link to him and the forum mod team
http://bt.custhelp.com/app/contact_email/c/4951
apulmax
Message 5 of 120
I have contacted David M and 1st line support and second line support as my broadband went down again this afternoon.
I boost engineer is coming out tomorrow, even though I have had several boost engineers out before and they couldn't fix it, I see nothing new.
I will continue to post my nightmare on here for everyone to see what I am experiencing from the so called biggest telecoms company in the UK.
I will be seeking compensation for the inconvenience and cost I have incurred by having to tether my network to 3G every time the broadband went down.
john46
Message 6 of 120
hi after the boost engineer has be if you have any further problems i recommend the you just deal with David M and the forum mod team that he is part of it will save a l;ot of confusion and frustration for you
apulmax
Message 7 of 120
Thursday 15th Nov at 23.15 and hey ho, down it goes, then comes back up at 23.20 with a 23k downstream and a 760k upstream. Same fault different day. Since July 2012 this has been happening.
I am keeping logs of all the speedtest I am doing for proof.
Second test at 23.30 downstream 30kbps - upstream 755kbps
Speedtester.bt.com does not work on Macs in Firefox or Safari, hasn't worked since July, I have reported it isn't working but no one has fixed it!
UPDATE: 23.46 downstream 0kbps - upstream 753kbps (doesn't that tell you something?) It's NOT a local network issue!!!
UPDATE: 00.54 downstream 3336kbps - upstream 760k (come on BT Wholesale sort your DSLAM out!)
john46
Message 8 of 120
as you have an engineer visiting you and David M is now involved as well all you can now do is wait while the problem gets resolved
apulmax
Message 9 of 120
UPDATE:
The engineers turned up this afternoon, with much prodding and poking in the exchange they have given me a new E side.
We both agreed we were not convinced this would solve the problem but the engineer told me to try and do a speedtester.bt.com on it, which would log and prove that I am suffering from these slow up/downstreams.
I told them that speedtester.bt.com doesn't work on any of my Macs as it hangs on 100% on the upload test.
Well I dug out a PC laptop and got it set up ready, and guess what?......yup, speedtest.bt.com hangs at 100% on the upload test then returns with "test error try again later, if this persists contact your service provider"
The beta works fine but they state the results are not recorded.
PLEASE CAN YOU SORT THIS OUT!!!!!!!
How can I give you information from the speedtester when it doesn't work? If you don't get the information then you can't fix the fault.
David M, please can you get this speedtester fault sorted? It's like a garage not being able to fix your car because the hydraulic lift doesn't work!!!!
dfenceman
Expert
Message 10 of 120
My neighbour has had a mac for 4-5years and the full BT speed test has never worked on it.
Best regards,
dfenceman
