Apart from the fact that one is bought and the other rented, is there any practical difference between the two systems?
The whole home wi-fi are individual networks, as you move from different areas the connection drops, then connects to the new disc.
Complete wi-fi uses a mesh system, so as you move around the connection remains seamless.
I believe the whole home wi-fi allow guest access, complete wi-fi doesn't.
The whole home wi-fi belong to you once purchased and have a manufacturer's warranty, complete wi-fi discs are included as part of the service, so you never own them but comes with a warranty so long as you subscribe to the service.
That's all I can think of now, others will come along with their advice, you can then choose what suits you.
In addition to @-Richie- ‘s comments, with the Complete WiFi you don’t have to have one disc permanently connected via ethernet cable to the router, as you do with Whole Home.
@-Richie-wrote:The whole home wi-fi are individual networks, as you move from different areas the connection drops, then connects to the new disc.
To clarify this, whole home wi-fi itself is a single network and does offer handover between discs without dropping connection in the same way as Complete Wi-Fi does.
But one difference is that whole home wi-fi is a separate network to the home hub (which may be what you meant). In fact we recommend switching off wi-fi on the hub for people who use whole home wi-fi.
Hope this clarifies.
is there any way to integrate the Smart hub 2 into a whole home wifi mesh? i currently have a whole home wifi disk sitting next to the smart hub 2 (itself a good fast router) with its wifi switched off. this seems a waste of a disk, electricity, and a plug socket! making the smart hub a 'base' for the mesh would be beneficial in myriad ways! Please consider this as a firmware update, if at all possible!
