Message 1 of 4
Complete wifi
I have 2 discs, everything was going ok and now the Wi-fi is shocking, keeps buffering, it’s easier to use 4G than the Wi-fi, what has happened?
if I need more discs do I need to pay for them ?
in the app I used to see the discs and what’s connected to them now I cannot find them, is there a way of finding out?
3 REPLIES 3
Message 2 of 4
Re: Complete wifi
Message 3 of 4
Re: Complete wifi
Hi @Payla1802
If this happened to me, I would reset the Hub and discs to factory default and set up everything as new rather than mess about trying to fix the issue.
http://bt.custhelp.com/app/answers/detail/a_id/11386/~/how-do-i-reset-my-bt-hub-to-its-factory-setti...
Message 4 of 4
Re: Complete wifi
Try resetting as suggested.
Regarding another disk, you can have up to 3 disks for free with complete wi-fi + Smart Hub. Call BT on 0800 800150, to get a new one.
If I have helped you in anyway please press the Kudo button (thumbs up)
If I have resolved your post please click 'Mark as Accepted Solution'
