Mazza
Message 1 of 1
Comtrend DH-10PF stopped working since hub changed.
Since I had my home hub changed to a black one my Powerline adaptor isnt working.
On the adaptor connected to the hub Status is green, no ethernet LED and AP LED is amber.
So it would appear I have no ethernet connection. I've changed the ethernet cable between the AP adaptor above and the hub and it is still the same.
On the adaptor downstairs the ethernet LED is green. I've tried re-setting the adaptor plugged into the hub but still the same.
Anyone any ideas ?
