Distinguished Guru
Message 1 of 5
Comtrend PLA question
I take it you can still use these with HH5 and YouView?
While waiting for the box to arrive I dusted them off got them set into the mains plugs all lights are go but my other devices line Appke TV seem not to work and I wonder what I am doing wrong, plugged Ethernet into the Apple TV to check.
Edit thumps head forgot about master and slave
Edit again still not working any ideas?
BTLife | 1967 Plus Radio | 1000 Classical Hits
Someone Solved Your Question?
Please let other members know by clicking on ’Mark as Accepted Solution’
Helpful Post?
If a post has been helpful, say thanks by clicking the ratings star.
4 REPLIES 4
Expert
Message 2 of 5
Re: Comtrend PLA question
Master and slave can be any way round Stuart, it makes no difference. They worked fine when I got Infinity at first. That was with the old Silver box and HH5. I presume you've done restarts of everything?
Distinguished Guru
Message 3 of 5
Had to do a complete reset before they worked but all fine now 😄
Helpful Post?
Recognised Expert
Message 4 of 5
Are they the original ones BT once gave to Vision customers, they may not be good enough for HD as they are not AV500.
Distinguished Guru
Message 5 of 5
No they aren't the original ones and I haven't taken HD
Helpful Post?
