tonywilliams
Message 1 of 7
Comtrend powerline adapters
I have a couple of the new Comtrend adapters. I haven't replaced my old ones because I'm not sure if these new ones work. When I plug them into the power socket I only get a red light on the status button. The other lights don't light at all. Is that correct?
Tony
6 REPLIES 6
raymie67
Expert
Message 2 of 7
Re: Comtrend powerline adapters
try
download.comtrend.com/PowerGrid902_UK.pdf
If my post was helpful then please click on the Ratings star on the left-hand side If the the reply answers your question fully then please select ’Mark as Accepted Solution’
Distinguished Guru
Message 3 of 7
Tony
It may be because the original adapters are still plugged in....
What happens if you unplug them and try just the new ones?
You can have more than 2 connected, but only one must be the set as the master
-+-No longer a forum member-+-
tonywilliams
Message 4 of 7
Thanks that was really useful link.
tonywilliams
Message 5 of 7
Followed the instructions from the pdf that raymie67 gave me and followed the instructions
KyleC_MUFC
Newbie
Message 6 of 7
I have 2 Comtrend 902 adapters. One is beside my xbox 360 and the other is plugged into my hub. The one beside the hub, all 3 of its lights are flashing red and i cant reset it as it wont respond!! Cant play online on xbox 😞    Help please  ??
Message 7 of 7
Hi have you tried the link posted by Raymie 67
