munko123
Message 1 of 21
Confused again !!!
Let me get this right, I cant receive BTS through youview as I don't live in a infinity area, and I cant receive BTS through BTVision as my local transmitter is only a relay. But isn't BTS fed through your BB line ?
20 REPLIES 20
munko123
Message 2 of 21
Re: Confused again !!!
Take it nobody has a answer.
legitimise_sailing
Distinguished Expert
Message 3 of 21
What was the question?
To say thanks for a helpful answer, please click the white star
munko123
Message 4 of 21
is BTS fed through BB line?
legitimise_sailing
Message 5 of 21
munko123
Message 6 of 21
Then why cant I recieve BTS through BB Line.
legitimise_sailing
Message 7 of 21
You can http://www.productsandservices.bt.com/consumerProducts/displayTopic.do?topicId=27270
"Requires BT Vision+ box with one off £10 viewing card cost."
StewM
Guru
Message 8 of 21
..and no.
If you have Infinity -yes.
Normal broadband - through an aerial or over broadband.
munko123
Message 9 of 21
I was told that because I dont live in infinity area, and my relay transmitter doesnt broadcast full listings. That i cant recieve BTS. This was after I was told that they would need to swap my youview box for a btvision box. that was due to be sent out but after a call from BT informing me said problem I am left withiut a way to recieve BTS except online which works fine.
guilbo
Guru
Message 10 of 21
Only some non-infinity exchanges have been enabled to carry it over ADSL, there isn't blanket coverage. So this may not be available in your area.
