Message 11 of 15
Re: Confusion of Fibre availability?
The BTWholesale page gives a little more info now...
BT BROADBAND AVAILABILITY CHECKER
Telephone Number 016******** on Exchange MONTGOMERY is served by Cabinet 3
Featured Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
WBC FTTP Availability Date
Left in Jumper
ADSL Products
Availability Date
Left in Jumper
Other Offerings
Availability Date
FTTP on Demand33030--Available----
ADSL MaxUp to 5.5--4.5 to 8Available----
Fixed Rate2 ----Available----
VDSL Multicast------Available----
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
This line is on a Market A Exchange.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014.
If the End User wishes to migrate from their current Broadband supplier they will need to contact the Broadband supplier they want to take service from to arrange for the service to be migrated.
Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number, NAD, UPRN or Access Line ID (ALID) check.
Note:
Thank you for your interest.
Message 12 of 15
More options but still no FTTC
Message 13 of 15
I guess Mr. Engineer was very much mistaken then. 😕
Message 14 of 15
I'd give it a bit more time.
Check the Openreach site again. See what it displays in the text box under the "cabinet journey"
Message 15 of 15
Try writing to openreach and see if they can check the database. https://www.formwize.com/run/survey3.cfm?id=7214&embed
If you get auto reply then send again until you get reply from a person
