Message 1 of 15
Confusion of Fibre availability?
So we've recently moved house, and have had to take a downgrade from Fibre to 'Standard' broadband.
Upon checking with all major suppliers, this is indeed correct. Nobody is offering Fibre, and the best speed estimate is 2 meg. So I re-subbed with BT. Familiarity and all that...!
Our engineer came today and have set everything up (brilliantly, top guy, router reports a 7968 downstream data rate) and upon returning from his trip to the cabinet/exchange said that we can definitely get fibre at our property. The cabinet was about half a mile away, and was certainly fibre enabled and he claimed to know that other people are already enjoying fibre just down the road (even further away).
All checkers say we can't get it, BT said no way when I was ordering (although i've not yet rang them with this engineer info).
I triple checked with the engineer and he was 100% certain.
So can the online checkers be wrong? Should I ring BT and persuade them to try again? Or could the BT engineer be incredibly wrong?
Thanks,
Matt
14 REPLIES 14
Message 2 of 15
Re: Confusion of Fibre availability?
Enter your phone number and post results. Remember to delete number
https://www.btwholesale.com/includes/adsl/main.html
Message 3 of 15
Whilst they may be futher away your line may be longer.
The way the network is routed can sometimes mean lines end up many hundreds of meters longer than the actual distance from the source.
Do you have the postcodes of the houses that are futher away that can supposedly get fibre?
Message 4 of 15
BT BROADBAND AVAILABILITY CHECKER
Telephone Number 016******** on Exchange MONTGOMERY is served by Cabinet 3
ADSL Products
Downstream Line Rate(Mbps)
Upstream Line Rate(Mbps)
Downstream Range(Mbps)
Availability Date
Left in Jumper
Fixed Rate1 ----Available----
For all ADSL and WBC Fibre to the Cabinet (VDSL or G.fast) services, the stable line rate will be determined during the first 10 days of service usage.
This line is on a Market A Exchange.
Throughput/download speeds will be less than line rates and can be affected by a number of factors within and external to BT's network, Communication Providers' networks and within customer premises.
The Stop Sale date for Datastream is from 30-Jun-2012; the Formal Retirement date for Datastream is from 30-Jun-2014.
If the End User wishes to migrate from their current Broadband supplier they will need to contact the Broadband supplier they want to take service from to arrange for the service to be migrated.
Please note that postcode and address check results are indicative only. Most accurate results can be obtained from a telephone number, NAD, UPRN or Access Line ID (ALID) check.
Note:
Thank you for your interest.
Message 5 of 15
How long have you had a phone line?
Message 6 of 15
I suspect it's a new line given the results of the checker. If so, it can sometimes take a couple of weeks for everything to align.
What results do you get for your number using this checker https://www.homeandwork.openreach.co.uk/when-can-i-get-fibre.aspx
Message 7 of 15
Hi Webby, thanks for your reply.
I can confirm that even though the line has been going from pole to house for 10 years, it is a 'new' number.
Here's my results from that link:
Your fibre service is connected from this exchange.
Exchange name: Montgomery
Exchange status: Fibre enabled
Cabinet number: 3
Cabinet status: Please check the cabinet fibre journey above
Message 8 of 15
Cab 3 is fibre enabled and accepting orders. Probably just need to wait until openreach database is updated for your new number then you will probably be able to order
Message 9 of 15
Ok, thanks Imjolly, so which website is best for me to keep checking? The BTWholesale one?
Cheers,
Message 10 of 15
Yeah that's the best one.
