SteveTheChef
Message 11 of 29
Re: Congestion on infinity 1 line
I will test again around 5pm and again in the evening tonight and post those screenshots too.
Again thank you ALL for you replies
pippincp
Sage
Message 12 of 29
The one from this morning has overwritten the previous one on the BTWholesale server so the further information it contained is no longer available.
Make sure when you do one later today when it slows down that you don't do any more unless asked.
SteveTheChef
Message 13 of 29
Ok thanks, I’ll get a low result tonight and stop testing.
I was doing a few tests to show my line does work well during off peak times and works terrible during peak. But I wasn’t aware of the overwriting so will stop this evening. Thanks
SteveTheChef
Message 14 of 29
Here is my latest test done today at 1740, shows the start of my broadband dropping down. it will carry on decreasing into the evening where it will be around 4mbps. I will post one more screenshot after this to show the evening then i will stop testingTest done today at 1740
SteveTheChef
Message 15 of 29
Last test run at 2030 today, I wont run anymore so this should stay on the system?test 23-12-17 2030.png
pippincp
Sage
Message 16 of 29
Yes, that one will be on the system. I doubt anthing can be done until next week though.
JohnC2
Moderator
Moderator
Message 17 of 29
Hi @SteveTheChef Thanks for that and I've checked and we have received your request and will be in touch with you as soon as we get to you after the bank holidays.
Cheers
John
SteveTheChef
Message 18 of 29
Thank you
StuartH
Moderator
Moderator
Message 19 of 29
Hi @SteveTheChef
Thanks for taking my call this evening.
Our suppliers are making changes as advised over the next 48 hours.  I will call you when you get home on Saturday to see if any improvements.
Stuart
SteveTheChef
Message 20 of 29
Hi Stuart
Prior to our phone call today I thought I’ll let you know I have ran a few speed tests through Ookla Speedtest and download speeds seem to still be dropping below what they should be. I haven’t ran one through by wholesale yet as I will await advise and am sure it will drop further during the evening.
Thanks for your support so far with this
