Message 1 of 3
Connect 3DS to BT wifi hotspot?
I can connect to the hotspot and log in on the browser on the 3DS, but whenever I try to connect on a game it brings up an error message. Even though I'm connected through the browser. I'm maybe trying to do the impossible but can you use the hotspot for games?
Tags (1)
2 REPLIES 2
Distinguished Guru
Distinguished Guru
Message 2 of 3
Re: Connect 3DS to BT wifi hotspot?
Welcome to the forum. I don't know how much bandwidth you need, but the maximum you can get from a BT WiFi hotspot is 3Mbps, and even that may be compromised depending on local conditions. Commercial (BT Openzone) hotspots go to 8Mbps.
Newbie
Message 3 of 3
1.Connect To BT Wifi with Fon
it should say atthe connecting to router
it should it faild
2.Go To The Browser
Try to go to google
it will take you to a
BT Wifi with Fon
buy login (make
sure you have allready
bought it) Then Log In
3.It Will Be Connected
Throught out the
system
