Message 1 of 2
Connect Whole Home Wifi Disc to Ethernet
Hi
One of my customers has a large property which has ethernet connections in many of the rooms in the property, I was thinking of buying a set of three BT Whole Home Wifi's and connecting each of them to the ethernet cables which run back to the main BT Hub 5, I am thinking this would ensure each of the discs which are going to be spread out quite widely would receive a perfect signal, rather than trying to chain them via wifi.
Is this OK to do this or should only 1 disc be connected via ethernet.
1 REPLY 1
Message 2 of 2
Re: Connect Whole Home Wifi Disc to Ethernet
@chrisw74
I am sure this has been asked before and the answer was that yes you can use them as wireless access points, and their performance would be much better than linking them via wireless.
