Drgarfield
Message 1 of 2
Connecting BTTV to hub 5 via secondary router.ui
hey guys.
Im trying to connect all my equipment to my hub 5, but iTs too far away and I don't want to use wifi for my ps4 or xbox1. So wot I've done is set up a second router as an access point, and connected that to my BT hub 5, and then connected at my devices (ps4, xbox1 and BTTV) to that router.
My xbox and ps4 all work great, but the you view box keeps saying that there is no connection, and to check my cables.
Any help would be great.
thanks.
1 REPLY 1
Keith_Beddoe
Message 2 of 2
Re: Connecting BTTV to hub 5 via secondary router.ui
All you need is an Ethernet switch, not a router, to connect Ethernet devices.
http://www.shop.bt.com/mini-sites/bt-connected-home/switches/
