Message 1 of 21
Connecting Digital Voice adapter without using WPS
I have an adapter to connect my DECT phone when my connection transitions over to digital voice, but I won't be using this with the Smart Hub because I have my own networking equipment. Is there any way to connect the adapter to my wifi without using WPS?
20 REPLIES 20
Message 2 of 21
Re: Connecting Digital Voice adapter without using WPS
digital voice from BT will only work with SH2  unless you have your own VOIP provider
Message 3 of 21
@glitchcrab
No, the adapter connects using DECT not Wi-Fi, back to the smart hub 2.
Message 4 of 21
well that's a non-starter for me. is it possible to use the smart hub in bridge mode? i could connect it as a client of my main firewall.
Message 5 of 21
Digital voice doesn't use wifi, the WPS button is a dual purpose button on the the SH2
Message 6 of 21
No
Message 7 of 21
If you wish to use a third party router, you will need to use a third party VOIP provider instead of BT's Digital Voice.
Message 8 of 21
The smart hub is the only device configured to communicate with the BT Digital Voice network. Its done that way by design, to ensure a secure connection.
Message 9 of 21
sure, i get that - the problem is more that I cannot use the SH2 as a client of my current firewall.
Message 10 of 21
Because the SH2 needs a direct connection to the broadband path back to the exchange, as the DV service is carried over the BT Wholesale IP network.
