West
Message 1 of 3
Connecting Laptop
I wonder if someone could give me some advice
I am trying to connect my laptop via a cable instead of wirless.
I have Win 7 OS and the wizard takes to a box which asks for my user name and password.
Is this the same as the information I have in the Hub i.e. user@btbroadband.com and then a password?
My hub shows no password.
I have tried but without any success.
I connect through wireless with no problem and my desktop is no problem
Many Thanks
2 REPLIES 2
Message 2 of 3
Re: Connecting Laptop
did you disable the wireless before you connected the ethernet cable? you should not need a username and pasword with the ethernet conenction - should be plug and play
West
Message 3 of 3
I may not have so will try that.
I did think it should just be a case of plugging in
The main connection from a set up point of view is through my desktop.
Many Thanks
