Message 11 of 19
Re: Connecting Netgear DG834GT to BT
you can if you use DGT - I do
coltal
Message 12 of 19
hi what do you mean by dgt?
Message 13 of 19
DG team firmware allows more control over your netgear router noise margin - does depend on version of netgear dg834
coltal
Message 14 of 19
the 834g has a differnet chip in to the 834gt as i understand, you cant alter snr on 834g with dg team f/w
. i have a black sky router which is a 934g or summit like that, i have flashed that to 834g f/w .
there is new f/w on dg home page for 834g but i dont have access to that, not registered so iam not 100% that snr cant be altered.
thanks colin
ps would appreciate the latest 834g f/w if you have it...
Message 15 of 19
which version of the dg834g do you have - I think it needs to be v4 to be able to alter NM
coltal
Message 16 of 19
that must be the difference.. mines only v2  ..  i  might leave it as infinity is supposed to be here sept 30th  just sick of waiting ,as its been dec 2010, march 2011, june 2011,
thanks for your time, ill try the username in the 834gt ,then ill give it up as a bad job.. i was hoping to use 834gt with infinty, but hopefully close enough to green box ill not need to twiddle and just use bt thingy..
thanks again colin..
Message 17 of 19
the 834gt will not work with infinity - you need a cable router and BT supply a separate modem and HH3 act like a router not modem/router
coltal
Message 18 of 19
thanks that will  save me messing with that one then..
colinSmiley Very Happy
coltal
Message 19 of 19
thanks to all ..  I put in username and password given by bt, i was putting in username@btinternet.com as in letter from bt . but as someone previously said username@btbroadband.com and my password and hey presto  connected with internet access.. on 834gt
thanks again
Colin..
