Just got BT FTTP set up with BT home hub. I want to replace this with my own Netgear D6400 Modem Router, which I have been using with Talktalk non fibre broadband for 18 months, until the swap over to BT last week. I know very little about how to do this, not even sure what the ISP Username or password is that it is requesting. I was helped to connect to Talktalk, with step by step instructions over the phone from Netgear when I bought it 18 months ago, I but don't think this is available to me now. Can anyone help please?
you need to connect the ONT to the netgear WAN port (not LAN)
username is bthomehub@btbroadband.com
password can be anything many just use BT authentication is on the phone number
the password is generic in that all bt residential customers use the same username and the real check is on your line phone number to confirm BT customer
are you connecting the ONT (modem) to the WAN port of the netgear
I'm pretty sure it's the WAN port. It's just marked internet, and is coloured red, same as the WAN port on the BT hub
Factory reset the router to clear out any old configuration and start again. I presume the Netgear has an auto setup wizard
I'll reset it, and yes, it has got a set up Genie.
I've reset to factory default settings. Genie gets stuck in a loop. It can detect PPPoE DSL internet connection, so I enter username and password as suggested, but keeps coming back to entering UK and BT again. I've also tried logging in to 'routerlogin.net' which also sends me into a loop and eventually says 'www.netgear.com's server IP address could not be reached. Of course, it's taking more time, as I have to keep swapping back to the BT hub to get any internet. Any other ideas please?
Are you sure you are entering bthomehub@btbroadband.com
Yes, but just to be sure, I'll do it again. Thanks
