Message 1 of 14
Connecting at G.DMT ?
Hello, I'm connected to Thamesmead exchange which has adsl2 and adsl2+ capability, so I was extremly disapointed to find out I have been connecting at G.DMT for over the past year since I changed from Be. How do I get my connection speed type changed ? do I have to call BT, is there a direct number rather then going through the possible 100 options.
Thanks Paul
13 REPLIES 13
Message 2 of 14
Re: Connecting at G.DMT ?
post your router adsl stats and also enter your phone number and post results  remember to delete number  https://www.btwholesale.com/includes/adsl/main.html
Message 3 of 14
BT BROADBAND AVAILABILITY CHECKER
Telephone Number  on Exchange THAMESMEAD is served by Cabinet 33
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date  High Low High Low
FTTC Range A (Clean)2013.71.70.8--Available
FTTC Range B (Impacted)17.17.91.20.6--Available
WBC ADSL 2+Up to 4--3 to 7Available
WBC ADSL 2+ Annex MUp to 4Up to 0.53 to 7Available
ADSL MaxUp to 3.5--2.5 to 6.5Available
WBC Fixed Rate1----Available
Other Offerings
Fibre Multicast------Available
Copper Multicast------Available
Message 4 of 14
It looks as if BT Wholesale have placed you on ADSLMAX up to 8mb service as moving you to ADSL2+ will offer no improvement in download speed and as adsl2+ is more noise aggressive than adsl max what is currently a a stable connection on adsl max may not be with adsl2+
Message 5 of 14
If that was the case, then why was I getting a higher connection speed when I was connected with Be, it was hitting 9000 kbps same exchange. <script>// // do MifDescShow(refwaninfo) to get wan information var nowWanPort="ADSL"; //var enblEnetWan = '0'; var prtcl = 'PPPoA'; var wanDesc=[["EWAN","EWAN",0], ["ADSL","ADSL",1]]; var ifcADSL="ADSL",ifcEWAN="EWAN"; var VIRTUAL_EWAN="0"; function init() { var idtbls = ["tbldev", "tblport"]; for (var i = 0; i < idtbls.length; i++) changeRowCr (idtbls[i]); chgWANRowCr(); if (typeof (FlashShortTime) != "undefined") { if (FlashShortTime ==1) var refreshTime=5; else if (FlashShortTime ==2) var refreshTime=8; if (FlashShortTime!=0) setTimeout("location.replace('/basic/status_basic.html')",refreshTime*1000); if (nowWanPort==ifcADSL) document.getElementById("pp").innerHTML="Protocol VPI/VCI"; else if (nowWanPort==ifcEWAN){ if(VIRTUAL_EWAN != "1" && "0" != "1")//!GZ document.getElementById("pp").innerHTML="Protocol VLAN ID"; else document.getElementById("pp").innerHTML="Protocol"; } } } function chgWANRowCr() { var idd = document.getElementById("tblwan"); if (idd == null) return; var cnt = idd.rows.length; var n = 0; for (var i = 0; i < cnt; i++) { for (var j = 0; j < idd.rows[i].cells.length; j++) { idd.rows[i].cells[j].style.backgroundColor = ((n % 2) == 0) ? "#E6E6E6" : "#FFFFFF"; } n++; } } function changeRowCr(idtbl) { var idd = document.getElementById(idtbl); if (idd == null) return; var cnt = idd.rows.length; var n = 0; for (var i = 0; i < cnt; i++) { if (idd.rows[i].style.display != "none") { for (var j = 0; j < idd.rows[i].cells.length; j++) { idd.rows[i].cells[j].style.backgroundColor = ((n % 2) == 1) ? "#E6E6E6" : "#FFFFFF"; } n++; } } } function showADSL() { var up_stream ='448'; var down_stream ='6080'; if(up_stream=='&nbsp' || down_stream=='&nbsp' || up_stream == '0' || down_stream == '&nbsp'){ document.write("<img src='/images/cross.gif' alt='' border='0'>"); }else{ document.write("<img src='/images/tick.gif' alt='' border='0'>"); document.write("448 / 6080 kbps"); } } function showPortWANs () { var nMultiPort=(wanDesc=="")? 0 : wanDesc.length; var up_stream ='448', down_stream ='6080'; var fspeed=""; for (var i = 0; i < nMultiPort; i++) { document.write(wanDesc[i][1]+'<\/td><td>'); if (wanDesc[i][2] == 1) { document.write('<img src="/images/tick.gif" alt="Up" border="0">'); } else { document.write('<img src="/images/cross.gif" alt="Down" border="0">'); } if (wanDesc[i][0] == ifcADSL && up_stream!='&nbsp' && down_stream!='&nbsp' && up_stream != '0' && down_stream != '&nbsp') { document.write('&nbsp;'+up_stream+' / '+down_stream+' kbps'); } else if (wanDesc[i][0] == ifcEWAN && wanDesc[i][2] == 1 && fspeed != "") { document.write("&nbsp;"+fspeed+" Mbps"); } if (i < nMultiPort - 1) { document.write('<\/td><\/tr><tr><td>'); } } } function showPhyVer() { //if(enblEnetWan != '1'){ if (nowWanPort == ifcADSL) { document.write("<tr>"); document.write("<td>Hardware Version</td>"); document.write("<td>Annex A</td>"); document.write("</tr>"); } } function do_connectPPP(prot,port,vpi,vci,id) { var idd=document.getElementById("idconnbtn"); if (idd != null) idd.disabled=true; var loc = 'do_connectPPP.cgi?pageFrom=basic&ppptype='+prot+'&portId=' + port + '&atmVpi=' + vpi + '&atmVci=' + vci + '&serviceId=' + id; var code = 'location="' + loc + '"'; eval(code); } function do_disconnect(port,vpi,vci,id) { var idd=document.getElementById("idconnbtn"); if (idd != null) idd.disabled=true; var loc = 'do_disconnect.cgi?pageFrom=basic&portId=' + port + '&atmVpi=' + vpi + '&atmVci=' + vci + '&serviceId=' + id; var code = 'location="' + loc + '"'; eval(code); } function do_release(port,vpi,vci,id,protocol) { var idd=document.getElementById("idconnbtn2"); if (idd != null) idd.disabled=true; idd=document.getElementById("idconnbtn"); if (idd != null) idd.disabled=true; var loc = 'do_release.cgi?pageFrom=basic&portId=' + port + '&atmVpi=' + vpi + '&atmVci=' + vci + '&serviceId=' + id + '&protocol=' + protocol; var code = 'location="' + loc + '"'; eval(code); } function do_renew(port,vpi,vci,id,protocol) { var idd=document.getElementById("idconnbtn"); if (idd != null) idd.disabled=true; idd=document.getElementById("idconnbtn2"); if (idd != null) idd.disabled=true; var loc = 'do_renew.cgi?pageFrom=basic&portId=' + port + '&atmVpi=' + vpi + '&atmVci=' + vci + '&serviceId=' + id+ '&protocol=' + protocol; var code = 'location="' + loc + '"'; eval(code); } // </script>
Message 6 of 14
sorry
Message 7 of 14
Message 8 of 14
You have fibre available which will give a faster speed - anything between 20 - 7.9mb so may be broadband with fibre which is infinity for customerswho can't get 15mb
Message 9 of 14
Be were an LLU provider using different exchange equipment but I wouldn't expect there to be much difference on adsl2
Message 10 of 14
Can you post adsl stats from your router
