Message 11 of 25
Re: Connecting dropping off again
The handback threshold applies to all ISPs. It basically determines the minimum speed you should get, and if the ISP can't meet it, then you can leave contract FOC. Hopefully, a mod will be along to help, as the disconnect frequency isn't normal.
Message 12 of 25
No it doesn't.
Message 13 of 25
Please explain then, because that's what I read.
Ah, I've written it wrong. I meant to say it's the speed at which you should get for your line length and other factors, it doesn't determine it, my bad.
Message 14 of 25
Also the handback threshold is purely between Openreach and the ISP. It has no bearing on the service offered by the ISP to the customer. The ISP may take it into considerstion though.
Message 15 of 25
Hmm, but if the ISP cannot meet the handback threshold, then the EU can leave contract FOC.
Message 16 of 25
That is conditional and not a given.
"If the fault is within our control and we are unable to resolve, you may be entitled to cancel your broadband contract without paying a charge for ending it early."
https://bt.custhelp.com/app/answers/detail/a_id/35296/~/your-line-speed-explained
Message 17 of 25
Drop outs, obviously I only notice the ones when I am using a divice connected to the intnent so there could be much more
17/02/2019 - 13:40
18/02/2019 - 01:45
18/02/2019 - 01:52
23/02/2019 - 19:26
23/02/2019 - 01:13
01/03/2019 - 14:16
Message 18 of 25
Welcome back, @Bobbydigital.
Please can you post the info again (line stats etc.) I think you've got the idea now. 😉
Message 19 of 25
1. Product name:BT Home Hub
2. Serial number:
3. Firmware version:Software version 4.7.5.1.83.8.236.1.2 (Type A) Last updated 16/07/17
4. Board version:BT Hub 5A
5. DSL uptime:0 days, 00:36:53
6. Data rate:19978 / 76343
7. Maximum data rate:28889 / 88055
8. Noise margin:10.7 / 6.1
9. Line attenuation:9.4 / 9.4
10. Signal attenuation:8.9 / 9.4
11. Data sent/received:2.5 GB / 57.7 GB
12. Broadband username:bthomehub@btbroadband.com
13. BT Wi-fi:Yes
14. 2.4 GHz Wireless network/SSID:BTHub5-2FNM
15. 2.4 GHz Wireless connections:Enabled (802.11 b/g/n (up to 144 Mb/s))
16. 2.4 GHz Wireless security:WPA2
17. 2.4 GHz Wireless channel:Automatic (Smart Wireless)
18. 5 GHz Wireless network/SSID:BTHub5-2FNM
19. 5 GHz Wireless connections:Enabled (802.11 a/n/ac (up to 1300 Mb/s))
20. 5 GHz Wireless security:WPA2
21. 5 GHz Wireless channel:Automatic (Smart Wireless)
22. Firewall:Default
23. MAC Address:18:1e:78:1b:d5:00
24. Modulation:G.993.2 Annex B
25. Software variant:AA
26. Boot loader:1.0.0
Message 20 of 25
Telephone Number 0208 on Exchange BROMLEY is served by Cabinet 68
Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Handback Threshold(Mbps)WBC FTTC Availability DateWBC SOGEA Availability DateLeft in Jumper  High Low High Low        Featured ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)WBC FTTP Availability Date
ADSL ProductsDownstream Line Rate(Mbps)Upstream Line Rate(Mbps)Downstream Range(Mbps)Availability Date
Left in JumperObserved SpeedsVDSLOther Offerings
Availability Date
Premise environmentStatus
VDSL Range A (Clean)8074201968AvailableAvailable--
VDSL Range B (Impacted)8072.4201967AvailableAvailable--
FTTP on Demand33030--Available----
WBC ADSL 2+Up to 8--5.5 to 12.5Available----
ADSL MaxUp to 5.5--4.5 to 8Available----
WBC Fixed Rate2----Available----
Max Observed Downstream Speed (Mbps)80
Max Upstream Observed Speed (Mbps)20
Observed Date2019-02-17
VDSL Multicast------Available----
ADSL Multicast------Available----
Bridge TapN
VRIN
NTEFaceplateN
Last Test Date22-02-2019
