Hi all I hope you can help. I have bought a fibaro home centre 2 which requires connected to LAN. I pluged it in to the back of my BT Home Hub. I also have a WD MyBook network storage device pluged in and working. The home centre then says to type an ip number into the web browser. I am on an imac snow leopard and have no idea what ip to use. It has a backup in that if you press a button it will set to a static ip and I have tried this but it finds nothing. I checked on the Hub manager and the device is not listed anywhere. How do I access this device?
